Fuel rail schrader valve
Old Jun 11, 2025 | 02:29 PM
brinny's Avatar
Default Fuel rail schrader valve
Hi all, i bought a cheap fuel pressure gauge to check my supply. None of the connectors fit the valve. Has anyone else had this problem and found an alternative fitting ? Ones I've seen are an arm and a leg! Thanks for any assistance in advance.
Old Jun 11, 2025 | 02:35 PM
bladerunner919's Avatar
Mine's just a normal Schrader - have you got a pic of yours?
Old Jun 11, 2025 | 02:40 PM
brinny's Avatar
Hi, mine is a normal schrader too , but none of the fittings in the kit fit it.
Old Jun 11, 2025 | 05:18 PM
kstevusa's Avatar
I used a flex tube from can old Fix a flat can, a copper barb fitting and cheap liquid filled fuel pressure gauge from Summit or Speedway Mtrs. WORKS GREAT
Old Jun 12, 2025 | 03:07 AM
dibbit's Avatar
The problem is a lot of these Chinese fuel pressure gauges come with a whole range of connectors and look very impressive in the photos, until you open the box and find that none of the connectors actually fits the Schrader on the car, which as you say is just a standard size. It's a bit of a mystery to me.
Old Jun 12, 2025 | 03:26 AM
This is the one I've got: https://www.machinemart.co.uk/p/clar...sting-kit-tes/
Not terribly expensive, but works great.
drmike
Jun 10, 2023 01:42 AM
egold56
General Tech Help
Jan 17, 2023 03:46 AM
orangeblossom
Dec 20, 2017 03:35 AM
ccfulton
Nov 21, 2012 06:13 PM
Palmero
XJ40 ( XJ81 )
Dec 21, 2011 10:43 AM
