Fuel tank pressurization issue and now p0440 97 XK8
Old Jun 30, 2015 | 06:52 PM
TreVoRTasmin's Avatar
Default Fuel tank pressurization issue and now p0440 97 XK8
So my 97 xk8 has always had a pressurization issue in that when you removed the fuel cap you would need to do it very slowly as there was obviously a pressure difference (air would run into the tank) and if you removed it too quick it would splash fuel all over the side of the car. Never had a check engine light or code for it until today. Got a p0440 code which is for a large leak. Checked the gas cap and no pressure there. I'm guessing my lack of attention to the first issue lead to the second so where do I start. Any ideas?
Old Jul 1, 2015 | 04:47 AM
jamdmyers's Avatar
There is a fuel tank pressure control valve that maybe stuck, see pic
Attached Thumbnails Fuel tank pressurization issue and now p0440 97 XK8-97emission.png
Old Jul 1, 2015 | 09:15 PM
But doesn't that just power up to run a test to see if it holds pressure? If it was stuck why would I always seem to maintain too a tank that doesn't seem to let air into it? Not real good at the EVAP syst
Old Jul 2, 2015 | 06:33 AM
mrplow58's Avatar
There isn't much more in the system that could cause a blockage. Do you have trouble filling the tank also? Lucky for you, it is a lot simpler to get at, than a convertible. I imagine with the warmer weather you are building some serious pressure. Since you already have a code, you could take a hose off of, or remove the valve completely for a bit, and see if the problem goes away. If it does, the valve is probably the problem. Good Luck....Mike
Old Jul 23, 2015 | 09:14 AM
johninuae's Avatar
With regards to the fuel tank not taking any fuel inside and pressure developing in the tank while engine is running.
We have already replaced the fuel canister but emission control faults are still there.
One of the pressure relief valve was damaged inside and we removed the broken pieces.
It hasn’t cured the issues and still pressurizing.
Please let us know can we get new pressure relief valve or maybe a used rebuilt working replacement tank
Can I get the pressure relief valve inside
Jaguar XK8 2002
VIN: SAJDA42C42NA30576
Thank You
John….
Old Jul 23, 2015 | 09:17 AM
johninuae's Avatar
Its a convertible in Dubai
toronadomike
Jan 22, 2026 10:13 PM
Charlene n John
Sep 28, 2015 06:01 AM
alpecsa
Sep 7, 2015 11:55 AM
Sprayall
Sep 3, 2015 07:49 PM
OkieTim
Sep 2, 2015 12:48 PM
