Fuel tank top assembly/interface shared by XKR & XK8?
Old Jan 1, 2020 | 04:56 PM
sanchius's Avatar
Default Fuel tank top assembly/interface shared by XKR & XK8?
Is the fuel tank top assembly/interface pictured below shared by 2001 XKRs & early XK8s?
Mine is damaged and there are two 1997 XK8s in nearby pull-n-pay yards.
(picture from stevenx506's post https://www.jaguarforums.com/forum/x...-access-118362
Old Jan 1, 2020 | 07:28 PM
DavidYau's Avatar
Default My 1999 XK8 doesn’t look like that
Don’t think so.
My 1999 MY XK8 doesn’t look like that.
Old Jan 1, 2020 | 08:10 PM
motorcarman's Avatar
2001 was the introduction of the different fuel pump/level sensor configuration. (From VIN A11051)
You would need a 2001/2002 4.0 XK EVAP flange if you car is the later one with level sender wires in the EVAP flange and not in the back of the tank.
bob
Old Jan 1, 2020 | 08:12 PM
giandanielxk8's Avatar
No. The XK8 all had 1 fuel pump, whereas the early XKRs had two. As such the top assembly was different to accommodate for this discrepancy.
Also, the assembly in that picture is for the 4.2 XKR which has a single returnless fuel pump that is very expensive (north of $700) and is again different from both the early 4.0 XKR, the 4.0 XK8 and most similar to yet still different from the 4.2 XK8 which is also returnless (and expensive) but the pump has lower pressure ranges; difference is about 5 psi if I recall correctly.
Old Jan 2, 2020 | 09:24 AM
JayJagJay's Avatar
What he said ^^^^^^
Especially the EXPENSIVE part! Jeeeeze Louise
Old Jan 2, 2020 | 09:34 AM
JayJagJay's Avatar
What is damaged? Not mendable? Epoxy and some fill in plastics? If it's the pump, there are Pulse Mod Pumps available (I just learned that PMod is a thing) --- don't mean to sound like a wise ***.... Drop it into the bucket, zip tie to keep it down and stable, and keep it moving...
I CANNOT pay $700 for a plastic bucket and some cheap hose,,,, and a pump that can be found for 70 - 120bucks... That's just me.
sanchius
Sep 4, 2019 08:51 AM
Calhale
Nov 20, 2012 07:45 AM
nglshmn
Sep 30, 2012 07:28 PM
calvindoesntknow
Aug 28, 2012 03:34 PM
SeismicGuy
Mar 12, 2010 10:58 AM
