Fuel Trims
Old Dec 15, 2013 | 05:57 PM
Bob OB's Avatar
Default Fuel Trims
Could somebody define "fuel trim" and how adjusting fuel trim is accomplished. Thanks guys... Bob
Old Dec 15, 2013 | 06:31 PM
WhiteXKR's Avatar
Bob, here is a good place to start: https://www.jaguarforums.com/forum/g...ed-quiz-49317/
Old Dec 15, 2013 | 08:32 PM
Gus's Avatar
Gus
Fuel trims can be a little tricky to understand. Why do you ask?
Old Dec 15, 2013 | 10:35 PM
Bob OB's Avatar
Thumbs up Fuel trims
My 2000 XK8 hasn't been up on the back of a ramp truck in a few months, so I thought it might be time to start worrying about things... Actually, my highway fuel mileage ain't that great...maybe 22mpg@ 70, I'm easy on the throttle and brakes. Maybe my fuel consumption is where it should be? I'll study the fuel trim primer and see if I can better understand the system. Thanks to all who contributed... Bob
Old Dec 16, 2013 | 05:02 AM
JagV8's Avatar
A generic intro to modern engines is on several sites such as OnBoardDiagnostics.com - Engine Basics
The very brief answer is that the critical sensors let the PCM estimate the fuel based on air and then adjust based on O2 sensors. It's why ALL the critical things must work.
This stuff is essentially forced on all car makers by law. (USA, Europe & just about everywhere.)
Old Dec 16, 2013 | 07:53 AM
Gus's Avatar
Gus
I would not be concerned until the car starts acting up. However, if you want to see what is going on you could perform a MAFS test to see if the air and fuel are within a suitable range. It will not tell you what is wrong but could ease your mind.
Old Dec 17, 2013 | 03:19 PM
OregonJag's Avatar
Originally Posted by Bob OB
My 2000 XK8 ... Actually, my highway fuel mileage ain't that great...maybe 22mpg@ 70, I'm easy on the throttle and brakes. Maybe my fuel consumption is where it should be? I'll study the fuel trim primer and see if I can better understand the system. Thanks to all who contributed... Bob
Not sure if the 2000 is much different than my 97 on fuel mileage. The best I've ever seen on my 97 is 25 and that's at the speed limit on the freeway and literally from gas pump to gas pump with no side trips and warmed up to begin with. I used to routinely put 600 miles per week on it between Portland and Seattle so I had the mileage pretty much dialed in. I've also got taller/narrower tires than stock (235/55-17) for better ride and less drag. Push it to 70 or 75, it knocks it down a notch or two. Around town normal is 17 for me if I take it easy, 15 if I'm getting ambitious. Now, the 03 and later models with the 4.2 and 6-speed is a different story. They'll get upwards of 30 on the freeway as I understand it.
Mike
RoyLittle0
Sep 17, 2015 01:05 PM
Bob Gelston
Sep 14, 2015 11:08 PM
SeanU
Sep 14, 2015 04:31 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
