Fuse Chart 2002 XK8/R FAQ
Old Nov 27, 2015 | 03:12 PM
obwoodie's Avatar
I looked at the photo I took of my 2004 xkr drivers fascia fuse box and the amperages are different from those in the 2001 and 2002 XK8. If you scroll down from the top LH side of the fuse box, the amps on my 2004 are: 20,10,5,10,25,5,10,10. then on the RH sdie of the fuse box they are: 20,10,30,5,15,5,15,10.
Old Apr 27, 2018 | 08:04 PM
thelongwayhome's Avatar
Thanks.. Question: does #1 fuse start on the right fuse bank on the car? #1 start on the top fuse bank also?
Old Apr 28, 2018 | 09:47 AM
Dr. D's Avatar
Although some of us need a flashlight and magnifying glass to see them, each fuse # is molded into the black plastic fuse box beside each fuse for all the fuse blocks.
Old Nov 27, 2024 | 06:49 PM
David Wichmann's Avatar
Default Fuse box diagram in the trunk
Originally Posted by test point
After answering a question on fuse location I realized that we have not posted a fuse chart on our FAQ Sticky.
Here is the one for my 2002 XK8. Other years may be slightly different but generally these should apply to all years through 2002 and perhaps beyond. I suspect that they may also largely apply to the XJ8/R series.
Thank you for your response. Do you happen to have the diagram in the main fuse box in the trunk? It shows all fuses and box locations?
Mine is not present.
Old Nov 27, 2024 | 08:49 PM
MVMonarch's Avatar
Does this help?
Old Nov 27, 2024 | 11:36 PM
Default 💯
Originally Posted by MVMonarch
Does this help?
That’s exactly what I needed. That is awesome thank you.
Old Nov 27, 2024 | 11:42 PM
for some reason mine doesn’t have that on the main fuse box in the trunk is there anywhere I can get that cover ?
Old Nov 28, 2024 | 02:58 AM
  #28
MVMonarch's Avatar
As I recall, these came on earlier cars only.
hoodun
Nov 20, 2022 02:35 PM
sedonajag
Oct 8, 2015 07:38 PM
gunlocators
Sep 30, 2015 08:05 AM
jessejamestw23
Sep 26, 2015 03:57 PM
