Fuse location pictures and descriptions
Old Nov 26, 2015 | 07:31 PM
obwoodie's Avatar
Default Fuse location pictures and descriptions
I have searched for photos of the fuse panels and the fuse functions for my new, today new, 2004 xkr convertible portfolio car. The seat stopped working after my wife set the memory 2 button for her and then touched the memory 1 button. The seat and steering column moved. Then I got in to program it for me and the seat worked for a couple of seconds and quit. It doesn't move at all. I cant find out what fuses work the seats and module.
Old Nov 26, 2015 | 07:42 PM
Gus's Avatar
Gus
Look in your owners manual it has all the fuse locations.
Gus
www.jagrepair.com
Old Nov 26, 2015 | 08:34 PM
obwoodie's Avatar
unfortunately I did not get an owners handbook or manual. I've been looking online but when I go to Topix and look for a diagram and click on it, it takes me to a Subaru!!!
Old Nov 26, 2015 | 09:41 PM
Gus's Avatar
Gus
Attached is a online wiring diagram for a 2003 MYC but it does not tell you the fuse layout but if you go to the page for the seats you can work your way back to the fuses for it.
Fig 12.1 - 12.4
Link.http://www.jagrepair.com/images/AutoRepairPhotos/jagxk2003.pdf
Gus
www.jagrepair.com
Old Nov 27, 2015 | 04:45 AM
test point's Avatar
Here is a chart of the fuse boxes for a '02 XK8/R. Your '04 will be very similar.
https://www.jaguarforums.com/forum/x...8-r-faq-33555/
Old Nov 27, 2015 | 01:45 PM
larueb's Avatar
Look in the fuse box located in the dash board hidden by the closed driver's door. Check the 2nd row from front. Should be a 20 to 30 amp fuse. replace the one that you find blown.
Old Dec 12, 2015 | 05:51 PM
55chevy's Avatar
My driver's seat wasn't working when I got it, but passenger's was. I switched some relays around to get AC console power back, and then pass side stopped working. WHen I check the 20 amp fuses in both facia fuse panels, they are not getting power to either side of fuse, what powers the fuse panel? A relay?
JessN16
Audio/Visual Electronics
Jan 13, 2016 11:47 PM
TheWarlock
Dec 26, 2015 04:46 PM
Mark SF
Nov 26, 2015 08:02 AM
Harmz
General Tech Help
Nov 25, 2015 05:21 AM
projectjag
Nov 22, 2015 12:35 PM
