gas tank question 1999 xk8
Old Dec 4, 2023 | 03:52 PM
Ship's Avatar
Default gas tank question 1999 xk8
When removing the gas tank do you need to remove all the gas? Or does the two gas lines when disconnected with the quick relace close stopping gas from draining out?
Old Dec 4, 2023 | 04:22 PM
cjd777's Avatar
The tank hoses are about 1 inch from the bottom, so removing with any tilt on the top towards the front will give you some gas in the trunk (boot)
You can get most out with a 44 inch 1/4 inch hose that has all the curve taken out of it.
I would still keep any tilt away from the holes at the bottom.
Gus has a great write up on getting the tank out.
Old Dec 5, 2023 | 02:15 AM
Pistnbroke's Avatar
If you are removing it to change the fuel pump you dont need to...remove parcel shelf/ speaker grill then cut the bit in front of the speakerleft and right towards the front and open like a sardine tin ..EPLS
53Steven
XK120 XK140 XK150
Sep 30, 2017 11:22 AM
1964Daimler
Sep 1, 2015 03:19 PM
wjd03
Sep 30, 2013 11:28 PM
rx8rotary
May 13, 2011 07:44 PM
