Gearbox Code P0783 (3-4) HELP
Old Nov 22, 2025 | 03:38 PM
Sethharttt's Avatar
Default Gearbox Code P0783 (3-4) HELP
Hi there, I recently got the code P0783 after back to back gearbox fault errors. Typically if I turn the car off and back on the fault goes away, it’s happened a handful of times within the past few years. Any idea how to fix this issue or what may cause it? I have a 2004 4.2 6 speed XKR. Could it be the solenoids? Where should I start? I also got code C1145 (Front Right Wheel Speed Sensor Input Circuit Failure) and (Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage).
Old Nov 22, 2025 | 06:10 PM
motorcarman's Avatar
The C1145 is 99% the link harness to the speed sensor.
The intake air temp sensor (P1111 if that is what it is) is a FALSE FLAG.
P0783
ECM Torque signal fault
Transmission mechanical failure
File Type: pdf
Old Nov 22, 2025 | 06:31 PM
Sethharttt's Avatar
P0783
What should I start by replacing or ordering?
Squider03
Mar 22, 2022 12:54 PM
mikebaker3
Jun 22, 2014 11:42 AM
kutom88
May 11, 2013 11:03 AM
BigKev
Dec 29, 2012 08:31 AM
