Gearbox Fault Warning question, re: vibration as cause...
Old Jul 2, 2014 | 04:08 PM
JessN16's Avatar
Default Gearbox Fault Warning question, re: vibration as cause...
I've gotten a Gearbox Fault warning, just randomly, a few times over the past month and it seems to come after hitting a bump or by getting some other vibration. I can immediately clear it by shutting the car off, then on, so it's more of a nuisance than a major problem, but it is bothersome nonetheless. On fault, the car will come out of overdrive and/or lock itself into a lower gear with poor responsiveness.
A pothole at 5 mph set it off today. Last week, because I have a tire somewhat out of balance and have a vibration between 50-60 mph, simply driving down a smooth interstate set it off.
It's a 1998 coupe with around 85k on the clock. I just bought a code checker (finally) but haven't checked the car; was mainly wanting to see if someone else has had a similar problem and could tell me the cost/difficulty I should expect in fixing it.
Jess
Old Jul 2, 2014 | 06:08 PM
Dr. D's Avatar
Howdy Jess:
Please check my post on the following link. It may be relevant.
https://www.jaguarforums.com/forum/x...-fault-112493/
Old Jul 2, 2014 | 10:17 PM
Paul Pavlik's Avatar
Just to be clear, the 98 XK8 uses a ZF Transmission and the 02 XKR uses a Mercedes Transmission.
Old Jul 4, 2014 | 04:48 PM
aode06's Avatar
READ THE CODE
don't feel bad a lot of us suffer from the same thing.
Old Jul 5, 2014 | 05:44 PM
JessN16's Avatar
A single code comes back -- p0706 Transmission Range/Performance
Opinions?
Jess
bamforp
Aug 14, 2024 05:36 PM
Jpav27
Jul 31, 2022 06:43 AM
cissdm
May 3, 2016 06:02 AM
giandanielxk8
Sep 6, 2015 07:21 PM
pnwrs2000
Sep 3, 2015 11:55 AM
