Getting The Grease Right
Old Jul 5, 2014 | 07:15 PM
Rezzz's Avatar
Question Getting The Grease Right
Changing the front and rear hub bearings and races and looking for a high temp and pressure grease replacement. Can not find anything specified in my manual for my 1999 XK8. When I tore down the existing ones I found much of the grease was gone from seepage out the rear seal where it built up as a black paste on the hub. A small amount in the front bearing race was still visible it was an off white in colour. Either way the grease had not performed well. In the spline I found barley any grease at all but I did find a light green film that had filled the grooves of the spline. It had semi-crystallized. Not sure what that was or what I should use in the reassembly. Any suggestions would be appreciated.
Old Jul 5, 2014 | 08:31 PM
plums's Avatar
The halfshaft splines? That would be more like Loctite.
JTIS may have a reference to a particular grease.
Old Jul 5, 2014 | 08:53 PM
Rezzz's Avatar
Yes the half shaft splines. Locktight seems a little much given everything bolts up tight as a unit. I will check the repair manual maybe they identify it.
kevinl
Oct 31, 2019 06:15 PM
JimC64
Oct 11, 2015 09:04 PM
mrplow58
Sep 15, 2015 09:58 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
Richard_gib
Sep 12, 2015 07:08 PM
