Gremlins in tail light
Old Jul 12, 2015 | 04:00 PM
larueb's Avatar
Default Gremlins in tail light
My '99 convertible has a strange problem. The left rear lights work fine until I slow down, using the brake and turn on the left turn signal. That causes the blinker to speed up and a "bulb failure" warning light to come on. If I use the turn signal alone it is fine and the same for the brake lights. It is only when both are used as the same time.
Any ideas! Thanks!
Old Jul 12, 2015 | 04:25 PM
<p>&nbsp;</p><p>check the connector going to the housing - the ground (black) lead may have fried.&nbsp; The easy fix is to install an extra ground lead - several threads on this issue</p><p>&nbsp;</p>
Old Jul 12, 2015 | 04:29 PM
<p>https://www.jaguarforums.com/forum/x...removal-84826/</p><p>https://www.jaguarforums.com/forum/x...esolved-35083/</p><p>&nbsp;</p>
kj07xk
Dec 18, 2025 10:56 AM
Rivguy
Dec 4, 2020 07:55 AM
SCMike
Sep 22, 2015 07:34 PM
motorhead69
Sep 9, 2015 10:04 AM
al_roethlisberger
Sep 7, 2015 10:53 PM
