Hand brake cable equalizer
Old Sep 13, 2020 | 06:09 AM
Higgins's Avatar
Default Hand brake cable equalizer
Assembling everything back in the rear suspension and drivetrain of my Xkr. I remember something about the importance of getting the cable equalizer with the correct side up. But cannot find any info on that now when searching the forum! Anyone who knows? Bulged side up or down?
Old Sep 16, 2020 | 10:53 PM
Higgins's Avatar
Bump
Old Sep 17, 2020 | 02:15 PM
PKWise's Avatar
Don't know.
The location and range of travel is very clear of all contact with no apparent obstructions.
I can only surmise that the reason for orientation is safety.
If the cable was somehow very loose (due to being stretched, out of adjustment or brake shoe spring failure), then it should never drop out of the captive 'U-shaped' channel.
Perhaps the thread adjuster side should be beneath the cable - which would help stop the cable loop falling out scenario.
Here's a pic of mine which seems to reflect that set-up (Cable over the screw adjuster) but I don't know for sure if this is right.
Old Sep 18, 2020 | 10:58 AM
jagophile's Avatar
Here is a picture of mine, as far as I can tell it has not been modified. Hope this helps.
Old Sep 18, 2020 | 11:03 AM
Higgins's Avatar
The "bump" seem to be on the upper side from the picture. Thanks!
35olds
Apr 21, 2020 11:50 AM
TheWarlock
Sep 18, 2014 02:48 PM
bocagq45
Jun 3, 2013 06:12 AM
Adam Lueb
Oct 22, 2011 07:54 PM
