Head rest repair
Old Apr 27, 2020 | 05:49 AM
STLTHMSTA's Avatar
Also good to know. This is what my headrest do and I'll put that on my list which really isn't that long.......for this car. My list for other things are astronomical or so it seems. :^) TM
Old Apr 30, 2020 | 10:00 AM
zecretw's Avatar
Hi all, I borrow this thread a little.
My headrest on my 2002 XKR has stopped moving up and down by motor power. However it takes no effort to raise it by hand and then gravity quickly puts it back in lowest possition.
Is this still the same problem or could it be something else broken? I am not a skilled mechanic so I want to know before starting ripping stuff apart.
Old Apr 30, 2020 | 10:13 AM
crbass's Avatar
You've likely popped the headrest out of it's nylon base. Should be no worries if the base is not broken. As noted, it appears to be nylon and is pretty robust in my experience.
To test, push down hard on the headrest to reseat it. If it doesn't easily come up, you're fine. If you want it freely moving again, just sharply pull upwards to pull it out again.
al_roethlisberger
Feb 11, 2018 04:38 PM
kennyjd
Mar 19, 2016 03:06 AM
CBurnett
Mar 21, 2015 11:05 AM
SteveGrr
Mar 4, 2015 08:31 AM
Poppyboy
Oct 16, 2014 11:18 PM
