Headlamp issues
Old May 10, 2012 | 06:16 PM
ToddL's Avatar
Default Headlamp issues
I have a couple of questions about the headlamps on my 1997 xk8. First, how do you adjust the headlamps. They seem to be one higher than the other. Second, how do you remove the headlamp assembly from the vehicle. I want to clean out the inside of the left headlamp as is it fogged......Thanks guys
Old May 10, 2012 | 06:36 PM
2002XK8Orlando's Avatar
The driver's side should be lower that the passenger side. If you shine them on your garage door you will see a stair step pattern made by the top of the cut off which is quite distint and this is normal
R & L
sometimes though the drivers side is low and you will see instead of three steps like in my crap illustration above you will see 4 with the fourth being in the middle section.
If drivers side there is a plastic finger that sticks out the back of the hieadlamp housing in the engine bay and a little adjustment acorn style nut the will adjust the lamp up and down.
Old May 10, 2012 | 06:38 PM
Pic of it is in this thread:
https://www.jaguarforums.com/forum/x...t-screw-71271/
Old May 10, 2012 | 07:44 PM
ToddL's Avatar
I will look into that. Thank you. You guys are great!
Old May 10, 2012 | 07:59 PM
RJ237's Avatar
As for condensation, just scroll down this page and you will find a thread titled Headlamp fix (condensation) which appears to be excellent. I'm going to try it also.
Old May 10, 2012 | 08:03 PM
AKINLOLU's Avatar
Can anyone tells me the location to a AACV valve on a 2000sj8
Old May 11, 2012 | 09:11 PM
H20boy's Avatar
you probably need the XJ8 forum AKIN, or the s-type
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Nasayr
Sep 9, 2015 06:20 AM
joey g
US Northeast
Sep 7, 2015 06:28 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
