Headlight Chrome
Old Dec 24, 2024 | 10:53 AM
pcolapacker's Avatar
Default Headlight Chrome
Any cheap fix for this? Can glass be detached to
​​​​​​gain access to pai​nt? Or go in from back?
Old Dec 24, 2024 | 11:12 AM
motorcarman's Avatar
Search for HEADLIGHT LENS.
https://www.jaguarforums.com/forum/x...needed-285747/
Old Dec 25, 2024 | 07:05 AM
bladerunner919's Avatar
If it were me, I'd separate the lens by baking in an oven, and then find someone that does silvering, which is how mirrors are made. Plastic can be re-silvered pretty easily by someone with the right kit.
Old Dec 25, 2024 | 12:16 PM
Hell-Cat's Avatar
I used Mirror paint from Culture Hustle with good results (even though I brush painted it). Search for 'Mirroriest Mirror paint' by Stuart Semple, a much cheaper alternative to vacuum coating.
Old Dec 25, 2024 | 01:08 PM
Riley VanSuetendael's Avatar
When I resprayed my ‘97, I took apart the headlights, heated the lens with a heat gun, and separated the glass. This gave me access to remove the failing chrome finish. Came off easily with lacquer thinner, but be careful as it dries out the plastic easily. Then I sprayed adhesion promoter, primer, dorchester gray base coat, and some clear coat. The results look amazing. It isn’t a full “blackout” look, but gives the headlights a darker, more modern look while appearing very OEM.
Old Dec 25, 2024 | 04:35 PM
wymjym's Avatar
any chance you could share a photo of finished repair?
WJ
Old Dec 25, 2024 | 06:25 PM
Thanks for the input. @Riley VanSuetendael I’d like your mod and would do but I have topaz metallic.
MudDog
Jul 24, 2022 09:21 AM
Gjbacci
E type ( XK-E )
Aug 17, 2021 08:47 PM
Mark239
Mar 16, 2015 06:39 AM
JimC64
Oct 27, 2014 09:59 PM
keiron99
Feb 18, 2011 02:09 PM
