Headlight Question
Old Jun 7, 2023 | 05:24 PM
bobhoff's Avatar
Default Headlight Question
2005 XK8. Right Side Dim Headlight not working. Changed bulb. Still not working. Check Fuses and they are OK. High Beam works. Does Ballast only furnish power to Dim Headlight?
Old Jun 7, 2023 | 05:49 PM
baxtor's Avatar
Yes, ballast is low beam only. High beam won't be affected by bad ballast.
Old Jun 7, 2023 | 05:55 PM
bobhoff's Avatar
Thank for the quick reply. I'll order a new Ballast.
Old Jun 7, 2023 | 07:38 PM
motorcarman's Avatar
Diagnosis is cheaper than throwing parts at the problem.
I would swap the igniter and bulb separately to the other side for conformation of the defective part.(one of them will likely NOT work)
Customers appreciate only replacing the defective component instead of the 'shotgun' approach.(just buy and replace EVERYTHING to be sure)
Just trying to save you money.
Old Jun 21, 2023 | 05:36 PM
bobhoff's Avatar
Did as Motorman suggest. Seems the igniter is bad on passenger's side. I have tried doing searches and can't find a source to buy new Igniter. Anyone know where I can get one or do I have to buy whole Headlight assembly?
Old Jun 21, 2023 | 06:20 PM
NBCat's Avatar
Have a look at SNG Barratt, one of the forum sponsors:
https://www.sngbarratt.com/English/#...assembly/30556
Lord_Eduard
Sep 1, 2020 10:35 AM
Aarcuda
20
Oct 1, 2019 10:45 AM
awil
Mar 23, 2015 06:35 AM
X-tyre
Feb 23, 2013 03:06 AM
