Headlight washers
Old Apr 11, 2011 | 05:44 AM
Marco's Avatar
Default Headlight washers
Not sure how but I used them last night for the first time. They definitly work. Sprayed all over the hood just after I washed it.
Old Apr 11, 2011 | 07:09 AM
Reverend Sam's Avatar
They spray automatically when you pull on the wipe stalk for several seconds.
Old Apr 11, 2011 | 09:02 AM
Brutal's Avatar
And with the headlights on, i hate em and theyre useless. If i had a xk ide cut the with to the washers for that exact reason
Old Apr 11, 2011 | 09:14 AM
You're typing on your phone, aren't you?
Old Apr 11, 2011 | 09:23 AM
Brutal's Avatar
NO, BUT DAMNIT YOU HAVE A GOOD MEMORY WHEN I TALK ABOUT WHERE IM AT DEPENDING ON HOW IM TYPING EITHER IN CAPS OR LOWERCASE.....IM AT WORK. I CAN OCCASSIONALY REMEMBER HIT THE CAPSLOCK BUTTON IM JUST EATING BREAKFAST AND GETTING READY DROP A HEADLINER ON A 2011 AND FIND SOME ROOF RATTLES OH FOR JOY I love my job, i love my job I love my job
Old Apr 11, 2011 | 09:52 AM
XKRacer's Avatar
Can not agree more, useless things, I have unplugged the pump on mine so they dont work
Old Apr 11, 2011 | 10:04 AM
XKRCoupeMan's Avatar
I thought they only worked every 10th time (or maybe 5th time) you used the washer. They look cool but how many times are these cars really going to be covered in mud or snow? Mine never gets dirty and the few times my headlight washers went off, I had to wipe down the entire hood (bonnet)!
Old Apr 11, 2011 | 02:26 PM
RCSign's Avatar
I plug the lines on mine I have never used them and the car never gets dirty enough to warrant them.
Doug
2001 XKR Silverstone
Old Apr 11, 2011 | 05:45 PM
Stratohammer's Avatar
My RH side washer spat out one of the nozzles and now gushes like Old Faithful! The next step for me is to plug the headlight lines. Do you think I'll earn some green points for helping conserve our planet's limited supply of windshield juice?
Mike
Old Apr 12, 2011 | 09:28 AM
Jag69's Avatar
How does one un-plug the pump or plug the washer hose?
Thanks!
Old Apr 12, 2011 | 09:58 AM
RCSign's Avatar
When I repainted the car I disconnected the fluid hose off the washer unit and put a bolt in the end with a hose clamp. and retied it up out of the way with a electrical tie. It was easy because the front bumper was off. You would probably have to remove you inner wheel well liners to gain access to the washers under the headlight assembly. This could be a tight area to work in and be careful not to knock off the washer it locks into the bottom of the headlight assembly and can be a bitch to install back on without taking out the headlight assembly.
Old Apr 13, 2011 | 05:47 AM
plums's Avatar
In slushy conditions they can be quite nice on a long haul at nihgt. You wouldn't believe how much light you lose due to dried on dirt and salt. When you hit the washers it's like night and day.
hoodun
Nov 20, 2022 02:35 PM
sunchip
Oct 5, 2015 02:05 PM
Col. Sandurz
Sep 28, 2015 07:29 PM
kevinl
Sep 24, 2015 08:25 PM
