Headlights turn off sometimes
Old Nov 17, 2019 | 11:21 AM
Norm 427's Avatar
Default Headlights turn off sometimes
Driving at night the headlights will turn off sometimes. I can turn them back on by using the manual switch on the end of the turn signal stalk. After a few minutes I can turn the manual switch back to normal and sometimes the headlights will stay on ... sometimes not.
I've searched the forum some but haven't come up w anything.
Any ideas? Thanks!
Norm
PS Coming back from dinner last night the lights at one point did what my wife calls a "flipper-doodle" ... they quickly seem to go off then back on very quickly, in a flash. ?
Old Nov 17, 2019 | 12:07 PM
dsd's Avatar
dsd
Do you have HID lights? The ballast or bulbs going south can cause this. I had similar issue and replaced the bulbs and it fixed it. Some had to replace ballast.
best!
Old Nov 17, 2019 | 12:38 PM
Diddion's Avatar
Are you using the automatic function for the lights, and does it happen when you have the lights manually switched on?? If on automatic only, I would look to the light sensor in the mirror (facing forward) or the connections to the sensor. If on both - automatic or manual - then it is not a mirror issue, and dsd’s suggestion is worth pursuing.
Old Nov 17, 2019 | 02:04 PM
Norm 427's Avatar
best!
They are Xenon headlights. So, yes.
Old Nov 17, 2019 | 02:06 PM
Norm 427's Avatar
It only happens when lights are in automatic function. So it may be the sensor in mirror.
Old Nov 17, 2019 | 05:49 PM
Johnken's Avatar
Norm, I've had the wire for the auto function work it's way loose 2 or 2 times over the years. The wire is soldered to a board at base of turn signal stalk.
Always proved to this fault by jiggling the turn signal stalk causing intermittent on off headlights.
Not too hard to fix should this turn out to be the issue.
John
Old Nov 18, 2019 | 05:37 PM
mhminnich's Avatar
I also had a wire break in the stalk switch, but in my case I had no lights regardless of switch position.
Carnival Kid
Mar 19, 2018 05:37 PM
kesslari
Aug 31, 2015 04:53 AM
jaguars4r
Dec 1, 2014 05:06 AM
bodykits
Exterior
Dec 6, 2010 01:38 PM
clnilsen
May 6, 2008 07:40 PM
