headlights, windshield, Radio
Old May 19, 2014 | 08:27 AM
kelliott's Avatar
Default headlights, windshield, Radio
I need some help with the following questions concerning my 2004 XK8.
  • How do I clear up the moisture in my headlights?
  • Radio ticks when listening to AM channels?
  • Windshield appears to have a pattern within the glass itself?
Any help would be appreciated.
Old May 19, 2014 | 01:33 PM
Johnken's Avatar
Radio ticks - did you change your ignition wires? As I recall some models without RF supression can cause this. On other cars, some have had sucess grounding the hood to the chassis (effectively turning it into a shield), but an ohmeter can tell you if it is grounded before you even consider this. I am brainstorming on this one, do a google on cars AM radio interference supression and see what you get. When you mention the windows - does it show only when wearing polarized sun glasses? I have to ask because that can explain it.
Old May 19, 2014 | 01:56 PM
Jag#4's Avatar
Here's a thread on moisture in the headlights. Post #18 even has Jag TSBs.
https://www.jaguarforums.com/forum/x...adlights-1316/
Other threads exist if this doesn't help. Just search for moisture condensation headlights. It's a common enough problem.
Old May 21, 2014 | 05:18 PM
kelliott's Avatar
Thanks for the info. The windshield is the same day or night it looks like threads running through the glass. It almost looks like a car cover was on the car for a protracted amount of time and left an imprint. I've tried to clean the windshield and it makes no difference.
Old May 21, 2014 | 05:58 PM
Do you have a heated windscreen? If so, it'll be the fine vertical parallel wires of the heating element embedded in the glass.
CaneCounsel007
Nov 13, 2015 09:05 PM
Jpav27
Sep 26, 2015 03:33 PM
al_roethlisberger
Sep 21, 2015 08:15 PM
1964Daimler
Sep 9, 2015 11:28 AM
laserguy
Sep 3, 2015 02:02 PM
