headliner cleaning question
Old Oct 26, 2015 | 08:49 AM
Dennis07's Avatar
Default headliner cleaning question
I've noted that several of the cognoscenti here recommend using brake cleaner for this job. So ... what's the best technique? Do we spray the stuff on the liner directly or on a cleaning cloth of some sort? Saturate the liner or just sort of dampen it? Some details please ...
Old Oct 27, 2015 | 04:43 AM
jamdmyers's Avatar
It may depend on how much you have to clean, a spot or a large area the whole thing? I've cleaned mine using Ammo **** cleaner and using a Steamer. I use this on all my cars interiors and carpets. (see ammonyc utube on headliner cleaning). The steamer was a easy sell to wife since she's a bit of a cleaner (I'm not complaining at all) and we use it on floors, bathrooms etc quite a versatile machine. Mine is a mid line McCulloch for 150. Good power and a number of att. It's very good at detailing too using steam to clean gaps between things on the jag.
Old Oct 27, 2015 | 08:57 AM
test point's Avatar
Just a brief spray of brake cleaner. You just want to get it damp enough to evaporate and take the stain with it. Don't plan on breathing much of the stuff.
Jaguar recommends rubbing alcohol so I put that into a spray bottle and nearly suffocated myself.
Old Oct 27, 2015 | 09:18 AM
As discussed, check Ammonyc.com detailing website, the guys great
Don't know about brake cleaner but whatever APC you may use, don't soak the headliner, its a case of spraying onto the cloth and dabbing, working in until stain is removed
Old Oct 27, 2015 | 05:02 PM
Dennis07's Avatar
Thanks, guys. Started poking at it with CRC brake cleaner and microfiber cloth. Looks like a good improvement can be had.
Tom, I'm not sure inhaling this stuff is a lot different from the rubbing alcohol.
Old Oct 27, 2015 | 10:04 PM
Jandreu's Avatar
Yelp, I made the mistake of just spraying mine with brake cleaner, have not been that dizzy in... Well we will not go there. Took three days to air the car out.
Old Oct 27, 2015 | 10:24 PM
XxSlowpokexX's Avatar
I used tuff stuff. Worked great Its a foam cleaner and can get it at most auto stores
derrickonline
Jun 5, 2020 08:48 PM
FDR
May 23, 2016 09:18 PM
Ymss845
Oct 26, 2015 01:16 PM
Arlo
XK120 XK140 XK150
Oct 21, 2015 06:53 PM
TomFType
Oct 21, 2015 12:06 PM
