Headrest Repair Instructions (Video)
Old Jun 6, 2017 | 12:37 PM
  #61
chopr's Avatar
Default Simplest, most permanent fix...
Most of this discussion seems to be how to reattach the cut sheath to keep it from separating later. Make it easy on yourselves... get a speedo shop to make a cable 18 3/4" long and slip it into the housing. Done. Forever.
Old May 17, 2021 | 10:53 AM
  #62
cgaechief's Avatar
Found this while researching the issue this morning. Seems like the best solution to date.
Old May 17, 2021 | 01:36 PM
  #63
cgaechief's Avatar
Default FINISHED!
https://www.youtube.com/watch?v=8lcA_b2aCFg
FINISHED!
I just completed both sides. From the time I posted this last post and this one I did both headrests. No heatshrink. I did just like this chap showed, except I put a dab of gorilla glue in each end before I pinched it just for good measure. I would have been done a lot sooner if I had figured out that bottom upholstery fitting sooner. When I got to the second side I laid bottom piece flat against the board and the folded the upper seatback piece under and it just snapped into place super easy. I think it took 2 hours total; getting tools, doing the work, putting tools away and then vacuuming up the dried up crusty old foam bits.
I think this fix is a done deal and won't have to be done again.
Old Jan 1, 2025 | 06:26 PM
  #64
Brian G's Avatar
Just a note of thanks to all the contributors to this thread!
i just completed the repair of my pax seat which was demonstrating the "runaway motor with no headrest movement" issue. I used the "cut off the cable ferrule, drill out the remnant sheath material, re-insert the sheath" method, and it works a treat.
Of interest is that reinserting the sheath can be facilitated by gently heating the raw sheath end with a heat gun. That will soften the plastic enough to ease the insertion.
H20boy
Dec 24, 2024 03:23 PM
Jaguar Forums Editor
Jaguar Press release
Sep 30, 2020 06:53 AM
millertic
Sep 20, 2015 10:14 PM
Sep 14, 2015 11:18 PM
Sep 4, 2015 09:18 AM
