Help!!
Old Dec 2, 2011 | 10:23 AM
iaindarcy's Avatar
Default Help!!
Hi! My name is Iain and I live in London. I was the happy owner of my x Reg 4.00 coupe xk8 until my engine light came on and after half an hour driving it's the limp mode comes up on the dash and she is restricted.
I had it diagnosed and the code was for the post cat Lamdor sensor. I bought a Walker product but that has done nothing to help. The original one is a Denso, so I’ve now replaced it with one but it still does not sought the problem.
I’m at a complete loss. HELP!!
(Cheers)
Old Dec 2, 2011 | 10:56 AM
XKRacer's Avatar
You need to re-read the codes, once we have those we can point you in the right direction
macbut999's Avatar
Hi Iain post up the diagnostic code if you know it please,it will be helpful to anyone viewing the post
Old Dec 6, 2011 | 04:58 AM
iaindarcy's Avatar
Hi there and thank you for your help! The code from the car is P1647. I hope this may help! Thank you!
Old Dec 6, 2011 | 05:27 AM
XKRacer's Avatar
It is a sensor code, does your CATs have 2 or 1 sensor, later cars changed to a 2 sensor CAT cant remember off the top of my head what the change over year was but was somewhere around that time I beleive.
If is a single sensor you will need to check the wiring, the plugs can be a bugger to get at and maybe a wire has been pulled, failing that it could be a ECM failure but unlikely, I have never had one go on me yet.
Old Dec 6, 2011 | 06:22 AM
Sean B's Avatar
I think X reg has upstream and down stream sensors - PO1647 is B bank upstream. Either, heater failure, short to ground or high voltage, sensing circuit open circuit, or ECM failure (highly unlikely!)
No wonder it's still there, they've replaced the downstream when it's the upstream.
Hope that helps!
Old Dec 6, 2011 | 09:29 AM
Reverend Sam's Avatar
Could it possibly just be that the codes need to be reset?
Old Dec 6, 2011 | 09:58 AM
Sean B's Avatar
not if the wrong sensor was replaced, it will remain until it's replaced, then a reset.
Old Dec 7, 2011 | 10:43 AM
iaindarcy's Avatar
Default Help!
Hi again! Thank you for your replys. My car has two sensores on each side, post cat and pre cat. Hope that helps. Thank you!
