Help with knocking noise at low RPM
Old Feb 15, 2013 | 11:14 AM
guzzi svt's Avatar
Default Help with knocking noise at low RPM
I have been chasing this knocking sound in my engine when in gear and goes away after a few minutes of warming up.
What do you think?
Unknown Knock? Video by guzzisvt | Photobucket
Old Feb 15, 2013 | 11:22 AM
SteveJacks's Avatar
Originally Posted by guzzi svt
I now this may sound crazy, but it's a crazy sound, I have heard leaks at an exhaust manifold, gasket installed upside down on a 1976 Javlin, and it sounded like a knock.
I have been chasing this knocking sound in my engine that goes away after a few minutes of warming up. You got me thinking maybe it's a loose plug that seal as the head warms. What do you think?
I don't think your noise is a lose plug. In the first video where you aren't moving the camera all around, to me it sounds like classic bottom end rod knock.
Old Feb 15, 2013 | 03:29 PM
Gus's Avatar
Gus
The old school way of checking for a rod or wrist pin knock it to put the car in “D” your other foot on the brake and accelerate just a little to put a load on the engine. If you have a problem with either one you will hear it knock then.
Old Feb 15, 2013 | 09:33 PM
guzzi svt's Avatar
No loose plugs on mine!
The noise sounds like it come from the SC but even with the belt taken off it remains.
The dealer said it seems come from below the engine too when they had it up on the lift.
But you onlt get a few minutes to check it out then it's gone and will only return when the engine it dead cold again.
Old Apr 15, 2013 | 02:38 AM
steveinfrance's Avatar
Bill, I've put your 'noise' into a new thread so it doesn't get lost.
Sounds too light to be a big end to me .
I've always heard them rattle more in the instant an engine is revved up and you'd expect it to get worse when the oil thins.
Try Gus's test.
It isn't something daft like a bad tensioner pulley bearing?
Old Apr 15, 2013 | 06:50 AM
WhiteXKR's Avatar
Shine a bright light on the belt tensioner and see if it is retracting in sync with the knock. I have seen one do this when the belt idler pulley bearing (not the tensioner pulley) was bad. Amazingly an examination of the pulley and bearing showed little evidence of the bad bearing except a slight tightness, but replacing it solved the problem.
mrplow58
Jan 21, 2024 05:53 AM
Mac Allan
Oct 27, 2015 04:49 AM
ccfulton
Sep 20, 2015 05:15 PM
hen555
Sep 7, 2015 11:13 PM
robiwhan
Sep 4, 2015 10:43 AM
