Help!! No start
Old Aug 1, 2016 | 11:30 AM
Dale Dunn's Avatar
Exclamation Help!! No start
Went to start car this morning and ignition will not turn on. Have battery unhooked and on charge at the moment just in case. 99 xk8 Conv
Old Aug 1, 2016 | 11:48 AM
brgjag's Avatar
need more details. Get any check engine light, if so did you get the codes?
What year is the car? Is it turning over when you turn the key or nothing at all?
Old Aug 1, 2016 | 12:30 PM
Dale Dunn's Avatar
99 xk8. Ignition switch will turn to first position only. When I open door window goes down as usual in conv but never goes up when I close door. Is now all way down. Interior lights come on and when I insert key steering wheel goes to my position. Ignition will not turn to acc or on position and shifter will not come out of park
Old Aug 1, 2016 | 01:29 PM
avern1's Avatar
Try this: My wife had the same problem. Grasp the steering wheel firmly and while turning the key gently move steering wheel left and right. She had parked and pressure was against the lock mechanism from the steering wheel.
If you haven't had any other problems this might be it.
Old Aug 1, 2016 | 01:51 PM
brgjag's Avatar
I have had this happen in other cars I have owned. I would agree in trying this.
Old Aug 1, 2016 | 02:02 PM
Dale Dunn's Avatar
WOW!!! Thank you both. I've been fighting this all morning. Hard to believe it was that simple
Old Aug 1, 2016 | 02:06 PM
Dale Dunn's Avatar
I've had this problem in other vehicles and knew about it but did not think of that on the Jag. As always I over complicated it������
Old Aug 1, 2016 | 02:14 PM
brgjag's Avatar
but I have never had one will it will go one position then stop, it would not come out of lock unless I moved the wheel
Old Aug 1, 2016 | 05:27 PM
avern1's Avatar
Dale just be thankful for a quick no cost solution LOL. They are few and far apart when caring for Cats. Glad to hear it worked out for you.
DJS
May 23, 2017 04:37 PM
Ray Robinson
Aug 1, 2016 07:43 PM
Kief
Apr 26, 2016 10:29 AM
NJ2003XJ8
Apr 12, 2016 05:12 PM
Jan 24, 2007 11:53 PM
