Help - P0603 - Powertrain code 2004 XK8 Convertible
Old Jul 27, 2022 | 09:35 AM
daro31's Avatar
Default Help - P0603 - Powertrain code 2004 XK8 Convertible
Yesterday I went to start the car to head off on a day trip and I got an engine check light and very stumbling running for just about 30 seconds before I shut her off.
I checked on my ELM 327 code reader and Torque Pro and got the error code P0603- Powertrain Internal Control Module Keep Alive Memory (KAM) Error
I have been researching this and have tried the hard reset touching the negative cable to positive for 30 seconds. I also tried the method of disconnecting the battery and leaving the ignition key in the run position.
The battery is in good condition and is always on a trickle charger between runs.
Now the car only will start and run for a couple of seconds before it dies from what seems like a lack of fuel.
I have attached a photo of what I believe is the Internal Control Module.
I have had this car for 7 years, it has 217,000 kms. on it and up until this it has always run like a champ.
The car is North American model and I am located in Ontario, Canada.
All suggestions appreciated.
Apparently there are different versions of this unit, this is from mine.
Old Jul 27, 2022 | 11:13 AM
JayJagJay's Avatar
That thing there is the ECM... That is the limit of my experience with anything you've said, and I am interested to hear what others have to say... My little brain is thinking about a leaky capacitor issue inside of the ECM?
And yes, good used ECMs can be found. If this in fact turns out to be the issue.
Old Jul 28, 2022 | 03:45 PM
michaelh's Avatar
The DTC list is pretty specific about this one:
Someone here reported that they had cleared the code and it didn't return, others not so lucky.
I would try to clear the code, do a hard reset and check the fuel pressure anyway before digging in deeper, just in case there's a separate issue .
J KF Sze
Oct 12, 2017 02:24 PM
jarrod_9427
Feb 3, 2015 05:55 PM
carelm
Jul 31, 2014 10:10 PM
zibby_uk
Aug 11, 2011 07:56 PM
vancity
Jul 29, 2009 12:22 PM
