Help with XK8 convertible headliner install
Old Jun 24, 2018 | 05:20 PM
dwafford's Avatar
Default Help with XK8 convertible headliner install
Can someone direct me to to the correct file folder in the JTIS to get illustrations/instructions for R&R of the convertible headliner in a 1998 XK8? I have the JTIS disk, but haven't been able to locate the correct file folder. I very carefully took videos when I removed the headliner, so that I would be able to reinstall the new one without (much!) difficulty, but the video files somehow got corrupted, and now I'm completely lost. Thanks for any help you can offer.
Old Jun 25, 2018 | 08:01 AM
toaster's Avatar
Should work.............................
File Type: pdf
Old Jun 26, 2018 | 05:36 AM
dwafford's Avatar
Perfect! I appreciate this so much!
Old Jun 26, 2018 | 10:09 AM
dwafford's Avatar
After reviewing this, it appears to cover the main headliner, but not the separate piece that fits around the rear window. Can you either send the section that addresses that, or direct me toward where to find it? Thanks again.
Old Jun 27, 2018 | 08:24 AM
toaster's Avatar
Thumbs up
That´s the same problem i have had, no instructions for the rear window frame.
I used the old frame and glued the headliner around it....................
Old Sep 15, 2021 | 08:42 AM
Per Greibe Soerensen's Avatar
Hello.
Can you tell me where you bought your headliner. They are very expensive in Europe, which is why I am considering buying in the US.
Thank´s Per
joeeaglefield1
E type ( XK-E )
Jun 29, 2017 03:29 PM
SpartanX
Aug 24, 2012 10:47 AM
Miami XKR
May 14, 2011 03:26 AM
Billimanius
Nov 15, 2010 03:42 AM
jagxkrtoofast
Apr 4, 2010 02:31 PM
