Help! Xk8 problems
Old Apr 20, 2013 | 07:55 PM
Fn2damax's Avatar
Default Help! Xk8 problems
I'm looking for a fuse diagram, not a wiring. Also looking for proper order of lines to running to the pump for a 1999 xk8. An individual shop took them apart ...
Too long to explain
1999 xk8
Old Apr 20, 2013 | 08:17 PM
WhiteXKR's Avatar
Please post in the XK8/R section so others can benefit form the information and you can benefit from a wider audience.
Another member (Domingo) generously put together this diagram.
The fuse diagram is in the owners manual. You can also trace all the fuses from the electrical diagram on Gus's website: http://www.jagrepair.com/images/Auto.../jagxk1999.pdf
File Type: pdf
Old Apr 22, 2013 | 05:26 AM
spuddyo's Avatar
Also there should be a map of all the fuses printed on top of the fuse box in the boot next to the battery. It has all fuse boxes shown.
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
