Hi - I need some advice about my transmission.
Old Jun 19, 2019 | 01:49 PM
Justin Husman's Avatar
Default Hi - I need some advice about my transmission.
Hello! I bought my 2001 XK8 in Feb of this year with 85k miles on it. I have some records from the PO, but they are spotty. When I try to use the manual side of the shifter, it gives me a transmission fault warning. If I turn the car off and just put it in D, it drives great and shifts just fine. I have now put 5000 trouble free miles on the car, so I'm thinking I might change the trans fluid, since I have no idea when it was last changed, if at all.
I'm considering doing a simple drain and fill to start with, then a complete flush in a year, when I'll replace the filter (especially if this doesn't fix the error problem).
I want to do this in order to avoid shocking the system if it's never been done.
If I do the simple drain and fill, can I use Valvoline Maxlife or some other equivalent to the original Esso LT71141 fluid?
Old Jun 19, 2019 | 10:04 PM
DavidYau's Avatar
Default Maybe microswitches in the J Gate module
As all is well in D - drive, it may be worth looking first at the J Gate gear stick module. Lots of microswitches in there that could be the source of the warning. Easy DIY check with a sticky thread with the Rev Sam Youtube video.
I’ve an old pic below looking at the J Gate module parts
Old Jun 20, 2019 | 06:45 AM
Scottsgreenjag's Avatar
From: Somewhere south of Grand Rapids, Michigan, USA
Before you change the transmission fluid, you might want to peruse the thread: https://www.jaguarforums.com/forum/x...ts-data-29800/
There's a wealth of information in there about our transmissions and fluid requirements.
Jsedita74
19
Dec 8, 2012 09:37 PM
afonda
Nov 3, 2009 06:58 PM
alwr333
Jul 10, 2009 10:29 PM
arthurlathrop
Mar 8, 2008 09:27 AM
Jan 2, 2007 06:45 AM
