Hole in Heat shield- is this correct??
Old Jul 16, 2019 | 01:05 PM
darbysan's Avatar
Default Hole in Heat shield- is this correct??
I was changing the engine ground strap when I noticed a large hole in the heat shield on the passenger fenderwell, opposite of the passenger catalytic converter. Hole looked to be ragged. Wasn't sure if it is supposed to be there, and just got mangled over the years, or if a PO did something for access?? Being new to Jags, need some sage advise!
This is a hole in the heat shield- should it be there??
Bolt hole on left is for engine ground strap in body, just to help locate where the hole is located.
Old Jul 16, 2019 | 08:34 PM
DavidYau's Avatar
Default Some pics in this old thread
Not sure if where/view angle of your pic.
This old thread has a lot of pics/links for you to cross reference
https://www.jaguarforums.com/forum/x...cation-214529/
But Can’t see your particularly large hole!
Old Jul 17, 2019 | 09:10 AM
fmertz's Avatar
Would this hole give access to the lower O2 sensor on the converter? Not everyone is aware of the better trick access...
Old Jul 17, 2019 | 09:15 AM
darbysan's Avatar
Based on the pictures in the cross referenced thread, the hole is there for clearance for the steering shaft on right hand drive cars. You can clearly see the shaft going through this hole in the picture. There is no access to the O2 sensor via this hole.
Johnken
Sep 1, 2017 02:38 PM
WhiteXKR
Nov 3, 2015 04:34 AM
bfsgross
Apr 8, 2012 09:13 PM
expedio2005
May 11, 2011 03:26 AM
JagStypeR
Jun 3, 2007 11:36 AM
