How to attach rear quarter window trim
Old May 8, 2013 | 02:43 PM
mike66's Avatar
Default How to attach rear quarter window trim
Just like the title says. Just got a replacement for my missing window trim (rubber and metal) and need to fasten it down. Stays in place with a push fit, but pops up when the window goes up. Will any epoxy work, or should I use something less permanent in case it needs to come off in the future?
Old May 8, 2013 | 02:48 PM
WhiteXKR's Avatar
You might try adjusting the tangs a bit...it is supposed to just press in place and stay. If you do use adhesive use a modest amount of clear silicone, which can be removed without too much difficulty.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
GordoCatCar
Jan 2, 2017 01:10 PM
OkieTim
Sep 8, 2015 04:48 PM
Tar
Sep 6, 2015 11:24 AM
