How to empty radiator coolant ?
Old Apr 24, 2012 | 05:36 AM
Jag_Generation's Avatar
Default How to empty radiator coolant ?
Hi,
someone could tell me hot to do for empty radiator coolant from a '99 XK8 ?
many thanks
Old Apr 24, 2012 | 06:20 AM
Originally Posted by Jag_Generation
Hi,
many thanks
Radiator drain plug is bottom right on the rear of the radiator. This is what you're looking for:
Just visible from above. Easier to access from below the car.
Old Apr 24, 2012 | 06:33 AM
RJ237's Avatar
Just remove the shield for the oil filter and use a large washer to turn. Like almost all cars the coolant has to run out on the frame and make a mess.
Old Apr 24, 2012 | 07:10 AM
thanks guys
Old Apr 24, 2012 | 10:24 AM
Mountaincat's Avatar
Isn't that the truth---the coolant drain on every car I've worked on is designed to go all over the frame and make a mess. I think that must be in the SAE (society of automotive Engr's.) handbook under cooling systems. "Priorty number 1: "Make sure radiator drain plug is placed to make the biggest mess possible."
Old Apr 24, 2012 | 07:54 PM
berlin1977's Avatar
Diffidently puts a damper on recycling for a quick repair.
Old Apr 26, 2012 | 10:46 AM
artstar's Avatar
use a shop vac at the reservoir
Old Apr 27, 2012 | 06:20 AM
Stumpy's Avatar
Some questions I have for future reference.
When renewing the coolant should you do anything to rinse/drain out the 'Recovery Bottle'?
When finished should you have any coolant in that bottle? So that if the system uses it, it is not just sucking on air?
Old Apr 27, 2012 | 07:41 AM
Whenever I've had wing liners off, there's been approximately an inch of coolant in the Recovery Bottle. With a total system capacity of just over 9 litres, I've never worried about this small amount.
In normal operation, coolant is drawn back from the Bottle by vacuum as the coolant in the Expansion Tank contracts. If the Bottle happened to be empty and drew air back, you'd then just have to top up the Expansion Tank.
Old Apr 29, 2012 | 03:50 PM
mike6348's Avatar
Is there a way to empty the coolant left in the block?
Old Apr 29, 2012 | 05:41 PM
Yes - but the remaining volume in the block is very small compared to overall coolant system capacity.
Jaguar XK8 - Cylinder Block Drain.pdf
The only readily accessible point is the cylinder block heater or the blanking plug where a heater hasn't been fitted.
hoodun
Feb 20, 2023 05:52 AM
Seth
Nov 1, 2015 12:17 PM
vwbusbits
Oct 13, 2015 03:43 AM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
