How to get moisture out of the spark plugs?
Old May 23, 2015 | 02:38 PM
GTM's Avatar
GTM
Default How to get moisture out of the spark plugs?
Hi!
I had problems with coolant level sensor and in the end it was the magnet in the expansion tank that was stuck.
I think I was bit too careless with water and got moisture in #8 cylinder spark plug because now I'm getting fault codes p0308 and p1314. Engine idle is quite harsh.
How would you advice to solve this problem? Would spraying lots of CRC 5-56 or WD40 help get moisture out without disassembling anything?
Old May 23, 2015 | 03:04 PM
RJ237's Avatar
You need to remove the coil cover and the coi. The plug boot should be cleaned inside and out, the coil the coil and plug wiped dry and the connector cleaned with electrical contact cleaner.
Justinb
E type ( XK-E )
Jun 21, 2023 05:29 PM
Poet
Oct 2, 2015 09:00 AM
reb1999
Sep 26, 2015 08:41 AM
BathoryFan
Sep 15, 2015 05:04 PM
Boeingtravel95
Sep 14, 2015 05:01 PM
