How I repaired my ABS
Old 03-03-2014, 09:48 PM
bigk9863's Avatar
Default How I repaired my ABS
This is How I was able to remove my ABS control box from the module without loosening any brake fittings. In the first picture I took the power steering reservoir loose (Leaving the hoses connected) and bungied it out of the way. Then I disconnected the electrical plug. Then I disconnected the windshield washer fill tube. Then I took the 4 bolts holding the module mounting bracket to the body. Then I carefully raised and bent out the bottom of the unit (as in the second picture). Then I slid the box off of the solenoids after removing the 4 attaching bolts. It slides right off and out. Repair the box any way you choose. Then reverse the procedure. I soldered mine after cutting open the box and resealed again. Brakes work great again and no bleeding required. I am sure that I am not the first person to do it this way. It is better to avoid opening up the brake system.
Attached Thumbnails How I repaired my ABS-power-steering-reservoir.jpg   How I repaired my ABS-abs-unit.jpg
The following 8 users liked this post by bigk9863:
cjd777 (05-02-2014), dennisw (03-04-2014), Jag#4 (03-27-2014), Jon89 (03-04-2014), LivewireRacing (03-27-2014), mike66 (03-04-2014), Sir Alex of Yotto (05-14-2016), SPIJohn (03-27-2014) and 3 others liked this post. (Show less...)
Old 03-27-2014, 02:55 PM
LivewireRacing's Avatar
Thank you. It looks like a lot less hassle your way. What size is the external star socket to remove the star bolts?
Old 03-27-2014, 04:47 PM
Looks like an E4. Did your repair work?
Old 03-27-2014, 05:11 PM
stevepaa's Avatar
I could not remove the box without hitting the brake lines.
Old 03-27-2014, 05:22 PM
Crap. And an E4 is too small.
Old 03-27-2014, 07:05 PM
RJ237's Avatar
Received 2,786 Likes on 2,229 Posts
It's E6. I bought a used abs and the screws were in so tight that I turned the head on one of them. They feel like they're going to snap.
Old 03-28-2014, 10:16 AM
bigk9863's Avatar
My bolts came out fairly easily. You may have to take the brake lines off to take the unit totally out and on the bench to get the bolts loose. (if the bolt is twisting off then it probably will break off no matter were it is). I used a hacksaw to carefully cut the unit open along the seam being careful not to protrude into the unit. Soldering was easy using info already posted.
The control box will slide off of the solenoid stems if you pull the bottom of the unit out (as per the Photo) without disconnecting the brake lines.
Old 03-31-2014, 08:38 PM
For a 2004 US model, it's an E5 external star socket. They came out very easily. With a 1/4" drive.
Old 04-01-2014, 05:33 AM
bigk9863's Avatar
Did the the control box come off as i described? I genuinly dislike getting air in my ABS system and will avoid it like the plague.
Old 04-01-2014, 03:23 PM
Yep. I realized the two brass nuts that attach the brake fluid container holder needed to come off. Once that bracket was free, I was able to swing the base of the ABS pump medially and extract the controller.
On one of my motorcycles I tried to bleed the rear brake. The ABS unit makes it really tricky. So, yes, I too hate getting air in the lines in the ABS brake systems.
Oh yeah, all the anti-rattle clips that hold the brake lines must come off. Of course, some broke due to age.
Old 05-02-2014, 06:52 PM
bigk9863's Avatar
Default my ABS repair
If you do not like air in your ABS module, this is how to do it.
Old 05-02-2014, 07:06 PM
bigk9863's Avatar
Sorry, I meant to repost this on another recent thread about ABS problems, but could not figure out how to delete it.
ericjansen
12-19-2021 12:20 AM
bdboyle
09-16-2019 05:58 PM
Sarc
09-29-2015 08:28 PM
flyrr100
09-29-2015 03:47 PM
John Fox
09-19-2015 07:56 PM
Quick Reply: How I repaired my ABS
