How to stop the seat back slop
Old Oct 13, 2024 | 09:34 AM
Shoreguy's Avatar
Veteran: Air Force
Default How to stop the seat back slop
As part of my almost finished full interior restoration it was time to deal with the front seat backs rocking when in the up and locked position. So once a plumber always a plumber, this is what I came up with.
I read that the seat retainer bolt had a 5/8” OD. Which is what 1/2” copper fittings are.
Thru them on the grinder (eyeball)
It works perfectly.
I know originally these were plastic bushings however, if you see or find any let me know lol.
Old Oct 13, 2024 | 09:50 AM
wymjym's Avatar
That looks good. Rothwell addressed this issue some years back, he found a chair leg bottom plastic that fit. I used them with success.
wj
Old Oct 13, 2024 | 10:30 AM
Shoreguy's Avatar
Veteran: Air Force
I saw Rothwell's fix and liked it but after cruising the big box stores and only being able to buy two dozen at a time from Amazon I decided to go a different route. The copper will never break and the soft metal will wear quite well.
Old Oct 13, 2024 | 12:03 PM
giandanielxk8's Avatar
That looks really good. I have been using PVC tube for the past few years, but the PVC is finally starting to crack.
Old Oct 14, 2024 | 08:56 AM
Old Matelots's Avatar
I copied this trick...quick, easy, cheap and works well.
Old Oct 14, 2024 | 10:11 AM
Shoreguy's Avatar
Veteran: Air Force
I guess both ways will work fine. I still don't see the plastic holding up well over time? As they say there's more than one way yada yada lol
adenshillito
Dec 21, 2022 07:13 PM
iramphal
Dec 19, 2022 05:56 PM
JaguarXKR
Jan 28, 2021 10:34 AM
RaceDiagnostics
Oct 28, 2018 12:08 PM
Cambo
Dec 10, 2011 10:21 AM
