How to test the hydraulic pump?
Old Jun 17, 2019 | 08:58 PM
scottatl's Avatar
Default How to test the hydraulic pump?
Anyone know of a direct way to test the pump. I cannot raise the top and would like to test the pump. I have already run some tests on the micro switches by the latch and they seem okay.
Old Jun 18, 2019 | 03:37 PM
Johnken's Avatar
Scott,
1) test for 12volts at the connector.
A) ignition on. Have someone press roof down button. Do you get 12volts? Yes goto 2.
B) No: use key in door to try to open.
12volts? No - Check fuse in trunk
2) yes 12volt reading. Does motor make noise?
Gotta run mate let's start here. Tell us results.
John
Old Jun 18, 2019 | 03:39 PM
Johnken's Avatar
Just noticed change open to close above.did windows go up key in door?
Old Jun 20, 2019 | 11:40 AM
Gus's Avatar
Gus
Did you find the problem?
Old Jun 20, 2019 | 02:31 PM
scottatl's Avatar
yep, motor was fine it was a line issue. thanks for every ones help!
WhiteXKR
Apr 16, 2013 03:36 PM
Reverend Sam
Jan 15, 2013 11:32 AM
moonpetal38
Apr 16, 2012 08:45 PM
jerry_hoback
XJ40 ( XJ81 )
Dec 11, 2007 11:30 PM
jerry_hoback
XJ40 ( XJ81 )
May 9, 2007 09:21 AM
