how to top up your diff oil
Old Apr 12, 2012 | 03:07 AM
RaceDiagnostics's Avatar
Default how to top up your diff oil
OK, my pinion seal is leaking and I need to keep the diff topped up till I can get the car booked in to change the oil seal in two weeks.
Sounds simple, started the job at 5 this evening, and finally finished two hours later :shock: :shock: :shock:
The problem is that access to the top up plug is very, very limited, I tried a 1/2 inch wobbly, but by the time the plug was half way out the back of the wobbly was fowling against part of the sub frame. In the end I had to cut off the end of an old 1/2 inch socket set extension and then grind it square, total length was 20mm. I used this in a 14mm ratchet spanner to get access and remove the plug. I then used a small hand pump to pump the new oil up into the diff.
What a royal pain in the ****. In the end about a 1/3 of a litre went in.
This is all you can see of the plug!
The tools.
On the job.
Getting the plug back in is just as much a pain, I wedged the plug onto the 1/2 inch bar with a bit of card so that it could be held in place before screwing it in.
Old Apr 12, 2012 | 05:18 AM
Don't you just love "sealed for life" components.
A.f.a.i.k. the capacity is 1.8 ltr. 0.3 ltr is some leak.
FrickenJag
Jun 16, 2025 02:15 PM
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
1100me
Sep 7, 2015 06:26 AM
giandanielxk8
Sep 6, 2015 07:21 PM
