hydraulic hoses
Old Mar 9, 2011 | 09:09 PM
reko19's Avatar
Default hydraulic hoses
Took a first look at my hydraulic hoses, it says "power packer" on them. I read somewhere on this forum that some of 1997 had better hoses installed that are rated to handle the pressure. Am I in luck here?
Also, it looks that the fluid was changed at some point to Pentosin and I just need to add it to the proper level.
thanks,
Old Mar 9, 2011 | 09:49 PM
test point's Avatar
The very early cars did, indeed, have a different hose manufacturer that seems to have survived the trials of many owners.
It would still be a good idea to install one of the pressure reduction solutions.
Old Mar 10, 2011 | 07:20 AM
reko19's Avatar
so i guess the ones I have are not the early ones...
Old Mar 10, 2011 | 07:50 AM
test point's Avatar
I believe that the 'Power Packer' hoses were better than the later ones but for more info than you ever wanted to know go to GUS's off-forum web site. http://www.gusglikas.com/autorepair.htm
Do you have a leak at the moment?
You need to read these two threads:
https://www.jaguarforums.com/forum/s...ad.php?t=27132
https://www.jaguarforums.com/forum/s...ad.php?t=42013
Old Mar 10, 2011 | 08:46 AM
reko19's Avatar
Don't think I have a leak, at least hope so. When I bought a car late last fall the guy tried opening the top but it did not work all that well, he needed to "give it a hand". I haven't touched it since. My plan is to refill the pump to proper levels, hopefully it'll do the trick and after that go with a V reduction method.
mikiep
Dec 20, 2019 07:37 PM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lubrication
Oct 1, 2015 03:56 AM
