IDS SDD
Old Dec 20, 2022 | 03:17 AM
Edmond124's Avatar
Originally Posted by slugger
ok, so I have a Cable(clone mongoose), have tried supplied SDD 160.4, that didn't work, also tried via VM, v125, 130, did not work either, so...is there a place where one can find installation files for say v130 or 125?
Cheers!
Bonjour, je suis nouveau j'ai besoin d aide j ai installé Sdd jlr mongoosse , je n ai pas d identifiant ni de code est il possible de m aider avec un code et identifiant. Merci
Old Oct 3, 2023 | 10:23 AM
tlindi's Avatar
Default [SOLVED] SDD unable to start IDS - only splash image and then nothing
Originally Posted by baxtor
SDD is supposed to revert to legacy IDS on cars it detects as too old for SDD but in my experience getting legacy IDS to launch is a problem.
I have had more luck with standalone IDS on my 2000 MY.
You will require Rotunda VCM, not mongoose.
I found out how SDD125 and SDD131 can launch legacy IDS with a simple trick:
1) Backup c:\Program Files\JLR\IDS\runtime\tabman.exe (eg rename it to tabman.exe.org).
2) Find IDS118.5 tabman.exe (example from here: https://archive.org/download/JLR_SDD...0SDD131.03.zip ) and
3) Place tabman.exe to c:\Program Files\JLR\IDS\runtime\tabman.exe
Now your SDD can launch Legacy IDS - Vóila!
Br, tlindi
Old Oct 3, 2023 | 11:50 PM
baxtor's Avatar
Br, tlindi
That is more or less how l run my IDS125, it was more so the later versions I found unhelpful. Even through the tabman option some simply froze or crashed.
Old Oct 22, 2023 | 05:36 PM
xalty's Avatar
Br, tlindi
130 and up tabman vin select is locked with a seed
Old Nov 5, 2024 | 06:25 PM
tlindi's Avatar
No they are not. But they are only if you launch tabman.exe outside of SDD.
I now used some 30 hours with Windows & IDS&SDD debugging tools to find trace of issue causing newer than 118.5 tabman,exe substitute to work.
To start Legacy IDS on SDD version greater to 118.5 (or so) you need to:
Find you PC manufacturer or model with windows command "systeminfo" (on Windows 7).
Add your PC Details to file "SystemInformationConfigFile.xml".
​​​​​​​First revealed here: https://www.jaguarforums.com/forum/x...3/#post2799343
Last edited by tlindi; Nov 6, 2024 at 03:07 PM. Reason: Solution to IDS Legacy launch from SDD
Old Nov 6, 2024 | 03:19 PM
tlindi's Avatar
Default Here more generic solution - any Machine is green!
Wrong alert! It actually doesn't work :-/
joeleerj
25
Aug 26, 2025 03:21 PM
nebelfuerst
General Tech Help
Jul 29, 2025 05:28 PM
Box
Oct 5, 2023 07:51 AM
sayitaintso
Jan 29, 2018 07:04 PM
barnter
General Tech Help
Apr 5, 2016 01:00 PM
