Ignition problem
Old Feb 23, 2015 | 05:36 AM
earlyred's Avatar
Default Ignition problem
The key will open the door but will not turn the ignition (Also the steering wheel goes up and down when I try to turn the key)
Any suggestions?
Old Feb 23, 2015 | 05:56 AM
test point's Avatar
Sounds like the key and transponder have lost sync. Do you have another key to verify if it is the key or the Security Module? If not I suspect you are going to get another one programed and synced to the car. A very high end locksmith is going to be required or a dealer.
Old Feb 23, 2015 | 08:29 AM
earlyred's Avatar
Thanks Test Point for the information. The key now turns 1 position but nothing. The battery is good. The key locks and unlocks the door. When the door is looked the beep of the alarm set sounds. I don't have a spare key. Since the door locks and alarm sets is that still a potential indicator that the key and transponder have lost sync?
Old Feb 23, 2015 | 09:24 AM
test point's Avatar
The key has a chip inside that is electronically queried by the ignition security system and must provide the response expected by that system. The door lock is a normal cut key lock.
Old Feb 23, 2015 | 10:05 AM
earlyred's Avatar
Again thanks for the help and information Test Point. I was able to start the car after reading another forum that suggested that I turn the steering wheel and see if that worked. IT WORKED.
This was the explanation I read (What is happening is that the steering colum/ignition lock is binding because the lock mechanism is being subjected to torsional loads from the load placed on the steering colum/igniton lock from the front tire/wheel asssemblies. Just give the steering wheel a tug to the left or right(which removes the load/binding from the ignition lock) and hold it in place and then the key will cycle completely and the engine will start. )
Again I'd like to thank the forum for their help and I'd appreciate any other suggestions.
Old Feb 23, 2015 | 10:46 AM
test point's Avatar
Sorry, guess I miss interpreted your meaning in the original post.
. . . but will not turn the ignition . . . .
Guess you meant that the key would not turn the ignition lock to the start position.
dsnyder586
Dec 29, 2024 07:39 PM
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Nov 23, 2015 01:56 PM
jagent
Sep 12, 2015 01:40 AM
avern1
Sep 8, 2015 06:25 PM
