I'm pulling my hair out over this car!!!
Old Nov 4, 2010 | 01:08 AM
edsterp's Avatar
Talking I'm pulling my hair out over this car!!!
It's been a about 6 weeks since my '98 xk8 has been down. Won't start. towed it to ******* (Jag dealer for newbies) I was told I needed a engine management harness. well they don't make them any more and say for me to look around for a used 1.(cost $250-400 for a used 1 from junk yard a.k.a. salvage yard, e-bay) and I knew I had 1 wire on em13 plug had a bad connection. well not wanting to put anymore money into this piece of..... I towed car back home. then I searched the internet for a new em13 plug. Its a 34 way multi-lock-40 female connector well after about 4 hrs I found it but no one had any in stock except tyco electronics. So I posed as a company interested in buying some 'cause there was a 500 mim. order and I only needed 1 so I reguest a sample and they sent me 1 free. So I fixed the by taking out pins 1 by 1 and any that I damaged (3) I had some from pins another similar connector pins from a lexes cause they use same connectors and denso ecm and I now have no codes at all or mesages on dash but dam junk still has no spark. Could it be a security issue? has very good gas pressure like 43 lbs and very good crank and no codes at all. go figuer!!!!!!!!!!!!!!!!!1 I checked the relays for injectors,tps and both have 3 sides that have good voltage when ignition is on but relay for ignition has 2 with good voltage and 1 weak 1 which is the black and blue wire which goes to em13 to or from relay which happens to be the 1 for spark, but why? (I think)
Anyway I hate this car any1 in socal want it? will consider all offers?
So I bout a better car but same colors and real power!
Old Nov 4, 2010 | 02:41 AM
XKRacer's Avatar
How does it sound when you turn it over? Does it spin fast? I have no idea if bore wash has been suggested but it is a classic reason if everything works and you still have no start
Old Nov 4, 2010 | 09:17 AM
H20boy's Avatar
Yes, describe the 'start' in more detail. Did you try to charge your battery first? With so many attempts to start it, and during the pre-electrical fix, you could have drained it to the point that it won't turn the starter. Fuel pumps sure...but not the starter. Try that.
Old Nov 5, 2010 | 11:45 PM
edsterp's Avatar
Question good battery
New battery, and no I didnt kill it I know that if it didnt start after a bout 10 cranks it's not going to. I tried with starting fluid just to make sure. It does have good /fast crank but I dont think white wash causes no spark or no voltage coming into ignition modules. I really think its a security thing because my battery did go dead
and while alarm was armed. Can the security module in trunk be by-passed?
Old Nov 6, 2010 | 10:18 AM
Reverend Sam's Avatar
Do you have more than one key? I'm not sure about the 98 XK8's, but most newer cars have a transponder chip in the key which communicates with the car's security system. If the security system doesn't read the chip, then the car won't start. Try using a different key just in case. Maybe the chip in your main key went bad.
Old Nov 7, 2010 | 01:41 AM
edsterp's Avatar
Default possible
N0 only 1 key and 1 fob I'll cal dealer on monday about that thanks!
xjrjag
Nov 27, 2025 09:16 AM
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
GroovyMom
Sep 3, 2015 08:08 PM
SatanClaus
Aug 29, 2015 09:15 AM
