I'm taking the plunge! Timing Tensioners!!
Old Jun 1, 2014 | 02:58 PM
convgto69's Avatar
Default I'm taking the plunge! Timing Tensioners!! UPDATE!!!!!
So guys I am finally taking the plunge and having my tensioners replaced. I decided to have it done by a mechanic. I found a 28 year veteran mechanic who worked for Jaguar here in NY. He's retired and still works on these cars for a fraction of what the Jaguar dealer charges. My car has 100K on it and the motor sounds great. The only way I can know for sure is have the motor opened up. With that I decided regardless of what he finds I am replacing everything new. Timing chains , tensioners the whole thing. Now I will have peace of mind and drive the crap out of this car. He is also going to chase down my dash light problem I posted earlier. I took my entire dash apart and could not find the problem. He has a good idea of what it might be. So I said fix it. Balance and rotate tires and this Jag is good for the summer and then some. I decided that this car is such a pleasure to drive and looks great I will make this investment and keep her for some time. I still plan on buying a second one a little newer but will keep this one as well. Thank you for all the great advise here which has helped me make this decision. I will update when I get her back this week.
Thx.
Jim
Old Jun 5, 2014 | 08:36 PM
convgto69's Avatar
Ok guys. Just got my car back from the mechanic. 100K on the car with original tensioners. Mechanic , who is a 28 year veteran was surprised the uppers were in such good shape. Needless to say I had everything replaced. Uppers , Lowers , timing chains , everything. Then I had him chase down the dash light issue where I blew the fuse everytime my headlights were turned on. It wa the plug for the radio that someone spliced in a wire incorrectly and affected the lights. All fixed. Balanced and rotated tires and changed spark plugs while he was in there. Car purrs nice. cruised home with the peace of mind that this engine is solid. I followed alot of good advise here and I want to say thanks.
Old Jun 5, 2014 | 08:40 PM
jonscot's Avatar
pass on that good karma, brother - best of luck during the summer motoring - and good to know about the radio wiring
Old Jun 5, 2014 | 11:05 PM
convgto69's Avatar
For anyone who is not sure if the tensioners were done, I have to say that my engine was running great. Quiet and smooth. I almost did not pursue the idea to check. Even when I had my mechanic listen he said it sounds great but you just don't know till you open her up. This car will see alot of road time tihis summer. From Manhattan to the Hamptons. Thx Guys.
Old Jun 6, 2014 | 12:37 AM
Sentinelist's Avatar
Well done!
Old Jun 6, 2014 | 05:36 AM
jamdmyers's Avatar
Did you look at the old tensioners and see if there were any cracks? How lucky were you ?
Old Jun 6, 2014 | 09:59 PM
convgto69's Avatar
The upper tensioners had no cracks. My mechanic told me that he was surprised and expected them to be cracked. The motor was so quiet before this was done and ran very smooth. But I could not sleep easy until I knew. Today I drove her over 200 miles. Top down in Manhattan all day. Then out to the Hamptons for the weekend. Runs like a dream. It was worth the peace of mind. Now I will drive her all summer every weekend without a care.
Old Jun 6, 2014 | 10:39 PM
Paul Pavlik's Avatar
There is a possibility that the Original Tensioners were already replaced in the past under the new car warranty.
Replacements at that time would have been Gen 1 or Gen 2 Plastic units.
Old Jun 7, 2014 | 01:47 AM
convgto69's Avatar
Anything is possible. I got lucky. I like not thinking twice about them.
JarodL
Mar 7, 2024 01:39 AM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
dcvickers
Sep 2, 2015 06:14 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
