Independent Jag mechanic or hobbiest
Old Jan 7, 2012 | 09:56 AM
doc18015's Avatar
Default Independent Jag mechanic or hobbiest
I posted on the XK8 forum, but will try here. I am in the Allentown, Bethlehem, Easton area of Pa and looking for a hobbiest or independent to work on the tensioner/chain replacement on my XK8. Send PM or call ***-***-****( Thanks for the help!
Last edited by joycesjag; Mar 3, 2012 at 06:46 AM. Reason: removed phone number after fix
Old Jan 7, 2012 | 05:12 PM
test point's Avatar
Have you ever considered doing it yourself? It really is not difficult and I, and any number of other forum members would be happy to talk you through it.
Old Jan 8, 2012 | 11:22 AM
doc18015's Avatar
Hello and thanks,
I think the most difficult part of it is the possible loss of cam timing and not doing the chains, lower tensioners and water pump at the same time. I have nearly 80,000 on my 97 with absolutely no noises or problems, but juat reading the problems on this forum caused the urgency to change all.
Old Jan 9, 2012 | 02:59 PM
Bamaman's Avatar
The secondary tensioner replacements are within the abilities of many owners. The full chain replacement is a pretty major repair, however.
Thankfully, the full chain replacement is not nearly often required as just the secondary tensioner replacement.
It's just a shame that there's no easy way to inspect the secondary tensioners without removing the valve covers. At that point, you could almost complete the repair with just a little more effort.
Old Mar 2, 2012 | 02:40 PM
GeorgeP's Avatar
Default K&T Vintage Sports Cars
Give Ken Beck at K&T Vintage Sports Cars a call. His shop specializes in British, and he does a lot of Jag work. 484-664-2353. He's located just off Airport Road South, a mile or two from Route 22.
Old Mar 3, 2012 | 06:27 AM
doc18015's Avatar
Many thanks! I took the risk of failure and completed it myself. Was not that bad although time consuming (approx. 5 1/2 hours). I am told not bad for first timer......had a ball doing it and had the chance to clean , change plugs, etc. Seems to be fine!
Could not have done it or would have started it without this great forum! Many helpful guys that have taken the so-called experts (factory..??) methods and have revised to a better standard.
Thanks to all that helped me through!!!!
Old Mar 3, 2012 | 06:47 AM
joycesjag's Avatar
WTG doc!!!!
Congrats on DIY'ing and thank you for the follow up.
Wolfy
May 28, 2024 08:06 AM
edtexas
Sep 5, 2015 10:49 AM
AL NZ
Sep 4, 2015 08:39 PM
obwoodie
Sep 3, 2015 07:45 PM
XFR_Gold
Sep 2, 2015 12:24 PM
