inertia switch 2005-2006 owners please advise
Old Dec 20, 2010 | 05:15 PM
wjd03's Avatar
Default inertia switch 2005-2006 owners please advise
99 xk8 - can anyone give me a detailed location of where the inertia switch is on this model? I have no fuel pressure and the fuses look good.
thanks
Old Dec 20, 2010 | 05:37 PM
wjd03's Avatar
Default facia?
located on the LH side of facia? what is that. no wondewr i cant find it. please help
Old Dec 20, 2010 | 05:45 PM
Gus's Avatar
Gus
The inertia switch is installed next to the fuse box in the LH end of the fascia (The Dash).
Attached Thumbnails inertia switch 2005-2006 owners please advise-inertiasw.jpg
Old Dec 20, 2010 | 06:36 PM
wjd03's Avatar
Thank you Gus! you are the man. I have been searching all day long for that thing. I want to see if it tripped prior to going into the fuel tank. I will post tomorrow after I look at it. I am still trying to defrost, as it is cold here in Virginia
Old Dec 20, 2010 | 06:44 PM
Gus's Avatar
Gus
Yes I know I am presently in Leesburg, Va I have a procedure on the fuel pump but first see if it has power and that the filter is not restricting your fuel. http://www.gusglikas.com/AutoRepairFuelPump.htm
Old Dec 20, 2010 | 07:04 PM
wjd03's Avatar
Default procedure
Yes I have been reading your post on that. Hope I dont have to, but the recources here are awsome and am sure I can do it.
Thanks Gus
Old Dec 21, 2010 | 03:26 PM
wjd03's Avatar
Default re Gus
LOOKED ALL through the area listed for the switch. Not locating it. Any ideas?
Old Dec 21, 2010 | 03:48 PM
wjd03's Avatar
Default re
I am now asuming that it is not a GFI type switch if that is the location. If so, how do I check it
Old Dec 21, 2010 | 05:52 PM
wjd03's Avatar
After more searching the onlt thing I am finding in there is a large block next to the fuse box, that has a rubber boot on it. Inside or under the boot is a spring loaded device. Does not look what I should be looking for tho
Old Dec 22, 2010 | 10:29 AM
cohibarandy's Avatar
I have an '05 XKR and the inertia switch is not located where it is supposed to be. Do I even have an inertia switch?
(then again, I have fuses where the handbook says there are supposed to be none)
Old Dec 22, 2010 | 11:26 PM
H20boy's Avatar
yes, booted thing is the switch...taken directly from the JTIS CD...if you dont' have one, definitely get yourself one for Christmas...$10 from ebay. Get the 2004 edition (has the 2004 XJ8 in it), its the last CD type out there. May be listed as a Jaguar TIS item...not JTIS.
2005... should be same spot.
Attached Thumbnails inertia switch 2005-2006 owners please advise-image1.jpg
Old Dec 31, 2010 | 11:45 AM
Mine is not there?? Left side or right side...
Old Mar 26, 2011 | 09:20 AM
thebrews1986's Avatar
It is on the drivers side fuse box. Open the box and look to the left you will see a black box with a rubber button on top of it. If it is the problem press down on the button and you will hear a click. If you tripped your inertia switch you would be experiencing a lot more problems. Codes like gearbox failure would come up electrical malfuntion. All kind of codes would come up and the car would not start or even try to turn.
Old Mar 26, 2011 | 09:21 AM
I am sorry it is on the right once you open the left side fuse box.
Old Mar 26, 2011 | 11:34 AM
No....you guys don't understand...the 05 xkr that I have does NOT have one there, where it is suppose to be...
Old Mar 27, 2011 | 08:25 AM
Default 2005 xkr inertia switch
Usually they are located in the truck jaguar is the only one that I have seen in the dash. If you are not the origonal owner it is possible the owner before you might have taken it out but i do not understand how the car would run without it. Unless he figured a way around it. The part is about 60 dollars and is a good thing to have. If you car drives I would take it to your local jaguar dealer. If it doesn't drive tell me some of the lights that are coming up in your cars dash I might be able to help you.
Old Mar 27, 2011 | 09:16 AM
beg3yrs's Avatar
Please post a photo of where you think it should be ....
Old Mar 28, 2011 | 08:39 AM
I don't need to post photos of where it should be. Because, there's nothing but fuses and maybe a couple relays.I know where the switch is supposed to be . It shows where it is supposed to be in the glove box manual. I am guessing the technology had changed by '05 and they were able to accomplish the task in a different manner. I am also guessing that if anybody out there has a late '05, or an '06 Jag XKR, that they will not have one in the side of the facia as well.
Old Mar 28, 2011 | 09:34 AM
H20boy's Avatar
calling the 05 & 06 XK8 - XKR owners...please verify location of your inertia switch
changed your title to attract a little more help, specifically in this case. hope that's ok
Old Mar 28, 2011 | 10:36 AM
Gus's Avatar
Gus
I hope this helps!
File Type: pdf
