Instrument Cluster Lights Flickering
Old Oct 13, 2016 | 09:11 PM
dsd's Avatar
dsd
Default Instrument Cluster Lights Flickering
All,
The lights on my instrument cluster have started to turn off and then on in a blink. It happens repeatedly but only instantly. No other lights seem impacted.
This happens both in auto and forced lights on.
Is there a potential for a loose connector (which and where)?
Thanks!
dsd
Old Oct 14, 2016 | 02:38 AM
There's 2 harness connectors on the bottom of the Instrument Pack. It usually causes more serious issues if these aren't locked in properly but definitely one possible cause to eliminate.
To access the IP connectors, first remove the bolster beneath the steering wheel to reveal the fixing screws on the bottom of the dash veneer panel.
Old Oct 14, 2016 | 07:12 PM
DaveInVA's Avatar
The other thing common to the dash lights is the dimmer rheostat. They can go flakey and cause that problem also. Shooting some contact cleaner in it may help.
Old Oct 15, 2016 | 06:21 AM
Plastic Paddy's Avatar
I had a similar ish issue and found that the battery terminals were a bit on the loose side.
Old Oct 18, 2016 | 08:56 AM
Jip's Avatar
Jip
Greetings;
The '05 XK8 was purchased a year ago. A Florida never seen rain car. When it saw rain in the Pacific NW right away the dash gauge lights started flickering. The shop found a terminal under the car which fastened a number of wires to a ground. Cleaned and worked for a year. Now the flicking is back. Will pursue.
Jip
dskul1
XJ40 ( XJ81 )
Aug 27, 2022 11:30 AM
dom777
XJ40 ( XJ81 )
Sep 30, 2016 12:03 AM
jeffwilson34
Sep 29, 2016 02:27 PM
Fashionista
Sep 19, 2016 04:08 AM
a6kmita
Sep 17, 2016 10:25 PM
