Instrument Cluster replacement. (Will it work)
Old Jan 1, 2025 | 06:39 AM
erjent's Avatar
Default Instrument Cluster replacement. (Will it work)
Hi All,
Happy New Year! After botching a repair attempt on my 2000 XK8 Instrument Cluster (LJD4300HC), I need to replace it.
I found a cluster from a 2000 Vaden Plas with a part # LJD4300GC. Should this work?
Much Thanks,
erjent
Old Jan 1, 2025 | 08:11 AM
motorcarman's Avatar
I have never tried to swap in a sedan INSTPK to an X100 but the VCATS will be important.
If you have a convertible, it may not be configured to display things like TOP NOT LATCHED or other messages?
You should try it. I know SUPERCHARGED and NATURALLY ASPIRATED are incompatible but as long as it is not a VID block car, (4.2 liter) it won't cause permanent damage if it is not correct.
Old Jan 1, 2025 | 08:24 AM
michaelh's Avatar
I can't find LJD4300HC in JEPC, but it is listed on the Heritage site, although without the VIN breaks shown in the catalogue:
https://parts.jaguarlandroverclassic...ment-pack.html
However, LJD4300GC is valid for MY2000 - depending on VIN:
...so could be worth a punt as motorcarman states. You can always resell it if not.
Old Jan 1, 2025 | 01:08 PM
erjent's Avatar
Thank you!
I didn't consider the sedan vs. convertible.
I'll let you know if it's a go!
erjent
erjent
Jan 7, 2026 10:06 AM
scottatl
Mar 3, 2024 01:06 PM
kemp neal
Jun 30, 2023 01:52 PM
Mycroft
Feb 3, 2023 11:09 AM
kreyszig
Jan 12, 2023 09:10 AM
