Intermittent Driver side door and window problems
Old Nov 11, 2025 | 07:32 AM
zray's Avatar
Default Intermittent Driver side door and window problems
If you have a window that won’t roll down, and driver side window / mirror switch that won’t function reliably, don’t buy a door module immediately.
First locate the door connector that is between the hinges. The connector unscrews which reveals gleaming electrical contacts. But some of them may be dull or tarnished. Or even have a greenish residue on them.
Take some CRC Electrical Cleaner and spray the contacts (both sides of the connector) liberally and wipe with a clean microfiber cloth. Spray again to remove any persistent debris. Let dry and reassemble.
Thats all it took to get my window switch back in working order.
With winter and wet weather coming on, it pays to give these connections some attention before the winter elements creep in.
Z
Old Nov 11, 2025 | 08:34 AM
Jon89's Avatar
Well done.
RaysSTR
Oct 7, 2023 03:53 PM
JaguarBarney
May 22, 2022 12:55 AM
Woodrun
Sep 18, 2018 10:51 AM
Mogmichael
Jun 26, 2016 04:01 PM
missmaryquinn
Dec 16, 2008 07:29 AM
