Window Won't Work
Old May 21, 2022 | 01:54 PM
JaguarBarney's Avatar
Default Window Won't Work
1995 XJS, 6. L V-12, 64000 miles
So the weather is finally warm and dry enough to take her out of hibernation. Washed her nice, put the top down to make cleaning inside easier.
The driver side window will not go down, won't budge at all. It was open maybe an inch or so and I put it up to wash the car. Passenger side works fine, and the small windows behind the door retract, as does the convertible top. I hear absolutely nothing when I press the window switch.
I'm going to examine the fuse first, but any suggestions on diagnostics would be appreciated. It'd be nice just to get the window down for her first ride of the season.
Thanks in advance for any insight.
Old May 21, 2022 | 02:19 PM
One update: I can hear the window motor engage if I press the up-direction, but nothing on the down-direction. Maybe the switch? Can I jumper a few pins in the connector to see if the window will go down?
Old May 21, 2022 | 02:41 PM
petemohr's Avatar
Here's the schematic. Not much to it.
File Type: pdf
Old May 21, 2022 | 04:10 PM
Easy-peasy!! Thanks petemohr.
Old May 22, 2022 | 12:55 AM
brinny's Avatar
Strip all 3 switches down and clean them. You will be amazed at the muck inside.
draganapiazzola
Aug 6, 2016 07:07 PM
RobertL
Jun 28, 2014 03:49 PM
G-Man
Oct 22, 2011 10:56 AM
RichmondXK
May 22, 2011 12:06 PM
Jaggyx
Jun 6, 2010 09:41 PM
