Intermittent power steering 2003 XKR
Old Jul 20, 2023 | 12:18 PM
cs81srq's Avatar
Default Intermittent power steering 2003 XKR
Hi Guys,
Just picked up a gorgeous new 2003 XKR and am experiencing a new issue. Basically, the power steering seems to work upon start up and when driving but then occasionally when I go to park or make a tight turn at low speed, especially when parallel parking, the power steering assist greatly diminishes. I have searched for similar issues in the archives and am not finding much help. One poster suggested using Lubrizol 6178. The reservoir has plenty of fluid in it and I am not finding any leaks on the driveway when I park overnight. Any ideas on where one would start to diagnose and fix this?
Thanks!
Corey
Old Jul 20, 2023 | 02:22 PM
Jon89's Avatar
Do you have service records indicating what type of fluid is in the power steering system? I would start by draining it and replenishing with the proper amount of Dexron III ATF....
Old Jul 20, 2023 | 03:17 PM
Pistnbroke's Avatar
Is the belt slipping ?
Old Jul 21, 2023 | 08:08 AM
cs81srq's Avatar
No service records with the car so I like your suggestion Jon and Pistnbroke that might be what is happening as well. Two great thoughts, thank you guys! I do not hear any chirping from the belts and I would guess that would happen if there was some sort of slipping but I will look at the belt and see if there is anything that looks off.
Thanks!
sigard
UK & Eire
Feb 12, 2024 08:12 AM
JaguarXKR
Aug 20, 2022 05:58 AM
giandanielxk8
Apr 1, 2019 03:10 PM
andys-GR
May 10, 2015 04:29 PM
sunchip
Jan 28, 2015 08:21 AM
