Jack stand placement
Old Sep 15, 2024 | 04:13 PM
RandyIsntMyName's Avatar
Question Jack stand placement
Is this a suitable place to set my jack stand? Jaguar 1999 xk8
Thank you!
Old Sep 15, 2024 | 04:52 PM
michaelh's Avatar
No.
Position it under the sill jacking point.
I would avoid jacking or supporting anywhere on the aluminium crossmember.
You can also use the radiator support if you're confident of its integrity.
Old Sep 15, 2024 | 08:38 PM
LMG's Avatar
LMG
Thank you!
I've followed the suggestions in this video with no trouble.
Old Sep 16, 2024 | 03:02 AM
RichardS's Avatar
Originally Posted by LMG
I've followed the suggestions in this video with no trouble. How to Properly Jack Up a Jaguar XK8 Using a Floor Jack (Also known as a trolley jack)
That is the recommended Jaguar method for jacking up both front wheels but, unless you take precautions then, in most cases, you will crack the plastic valance. People have successfully used wood with a slit across it to protect the vertical strip but I take the "no risk" approach and simply remove the valance and the use a block of wood against the metal crossmember to spread the load.
If I want to only jack up one wheel but can't use the sill jacking point, I use a low-profile trolley jack with a block of wood to spread the load right up against the inside of the tyre so the wood is under the lower ball joint and as close to the wheel hub as possible. It's not the recommended method but, bearing in mind the vertical loads experienced through that joint when hitting a bump in the road, I reckon that the weight of one side is well within spec and over 25 years of this method suggests that it is acceptable.
Richard
Old Sep 16, 2024 | 06:39 AM
Jon89's Avatar
I use a wooden 2x4 about 24 inches long placed below the aluminum crossmember to spread the load. Always done it that way since purchasing the vehicle in early February 2012. Works for me....
Ant Buck
Feb 22, 2025 03:00 AM
Jdwoody17
Jul 4, 2022 09:28 PM
MaxTorq
Jan 27, 2022 09:05 PM
Imanonamas
May 20, 2018 06:51 AM
compdude97
Feb 4, 2010 09:11 PM
