Jacking up the front
Old Jan 30, 2018 | 07:19 AM
Barry_Tucker's Avatar
Default Jacking up the front
I want to jack up my XK8 to do some work and am getting conflicting info on how to do it. Some say to jack under the cross member under the rad and others not to, because it will bend. Does anybody have any definitive advice or better yet practical experience ?
Old Jan 30, 2018 | 07:53 AM
Johnken's Avatar
I have used the spot under the radiator support, as recommended by rev Sam, many many times without problems. That's how I get her high enough to place Jack stands in the notches for the Jack, just behind the front wheels.
John
Old Jan 30, 2018 | 09:11 AM
Jon89's Avatar
I also jack up the front using the cross member below the radiator. But I place an 18-inch section of 2x4 lumber between the bottom of the cross member and the jack contact point in order to spread the load. Never had an issue while doing this....
Old Jan 30, 2018 | 10:56 AM
blindside's Avatar
I also use the cross member below the radiator without ANY issues...
Old Jan 30, 2018 | 11:12 AM
Cheers folks ...I have a low profile 3 ton floor jack with a nice wide rubber covered saddle, but I'll put a bit of 2x4 on top as you have suggested. Under the rad just seemed like a weird place to jack up a heavy car.
Old Jan 30, 2018 | 12:54 PM
Straight from the horses mouth.......
https://www.jaguarforums.com/forum/a...pages-1-60.pdf
multistrada74
Jul 8, 2015 10:13 AM
Gungebucket
Jul 4, 2015 11:46 PM
tberry6686
Feb 16, 2014 05:35 AM
Rev
Jan 17, 2010 08:37 PM
XJ40 ( XJ81 )
Nov 27, 2006 03:21 AM
